Results 1 to 11 of 11
Thread: 3.1's and boost
  1. #1
    3.1's and boost
    im thinkin of over the winter turbo charging my 3.1 and dropping in a 5 speed and i was alittle worried at how the engine would handle the turbo. and if theres anything i should do to the engine to make sure it doesnt blow from the turbo i'm not to sure what kind of turbo i'd be useing so any ideas would be great. the engine has 200,000 km on it but has been running fine and leaks or burns no oil but is it worth it or am i just asking for trouble? thanks
    1990 grand prix 3.1L
  2. #2
    1990lumina's Avatar
    Join Date
    Sep 2004
    Location
    Saskatoon, SK, Canada
    Posts
    6,170
    Thanks
    1
    3.1's and boost
    Holy shit another Saskatoon member
    So anyway, PM TurboSedan....he turboed a 3.1 with over 200,000miles if I recall correctly...
    There are other member who can chime in as well, FREE BUMP...
    Jeff L. :: 2nd Canadian to win COTM The Preservation for POS W-bodies Canada Chapter
    2004 Acura TSX | 2.4L I4 iVTEC; 5 Speed Auto | 1 of Many Made In '04 | 89,XXXKM
    1990 Chevrolet Lumina Euro 3.1 | 3.1L 191ci 60º V6; 440T4 | 1 of 43,912 Made In '90 | 194,XXXKM
    1985 Mazda RX-7 S | 1.1L 70ci 12A Twin Rotor RE; 5spd | 1 of 63,105 Made in '85 | 130,XXXKM
  3. #3
    3.1's and boost
    The bottom end is strong enough for mild boost levels (like 12psi or less) and the compression is also plenty low enough for boost (8.9:1). The only thing that you'll have to worry about is just setting it all up so it will work properly. For engine management I would recommend a TGP chip and all of its stock management stuff.
    Shawn
    99 Grand Prix GT 242,800+ miles<br />9.75:1 L36|K&amp;N|No Cat/Ubend/res|160 tstat|UD ALT|Shift Kit|Powertuner|Ported M90/LIM/TB/Heads|XPZ|Stg 2 IC|Pacesetters|ElecWP|AlumCradle|4340 IS|2.93 15/16&quot; Chain|2750 stall|2.55&quot;. <br />379.9whp on 93 octane, 11.9912 @ 112.99 w/1.729 60&#39;<br />Gen V/N* TB/3.69s since ET.<br />03 CBR 600RR Stock.&nbsp; 11.38 @ 123.64
  4. #4
    TurboSedan
    3.1's and boost
    22pg thread on everything i did with a TON of pics here:
    http://www.w-body.com/forum/viewtopi...=22683&start=0
    still running great, although i'm still working all the bugs out of it. it was a very low budget project but the results have more than blown me away 8)
  5. #5
    Join Date
    Apr 2003
    Location
    Cincinnati, OH
    Posts
    17,684
    Thanks
    1,194
    3.1's and boost
    I've always wondered, didn't they lower the compression on the boosted engines from the NA engines? If so, wouldn't a 3.1 that wasn't boosted originally be a better overall choice (for the fun factor) than an engine with a bit lower compression?
    EDIT: This is not taking into account all of the other TGP specific engine parts, just the compression ratio itself. I've always wanted a high compression, rev crazy, boosted car.
    Chris D.-
    '02 Buick Century- Wife's
    2012 Jeep Grand Cherokee- Company Car/DD
  6. #6
    TurboSedan
    3.1's and boost
    the Turbo 3.1 has a compression ratio of 8.8:1, whereas most NA 3.1s have a compression ratio of 8.9:1. not much difference at all of course. the difference in CR is in the heads (and it is noticeable when looking at them side by side). i believe the '89 NA 3.1 used the same heads as TGPs did but i'm not positive about that.
    fwiw i did use TGP heads on my engine so i'm at 8.8:1 CR.
  7. #7
    Join Date
    Apr 2003
    Location
    Cincinnati, OH
    Posts
    17,684
    Thanks
    1,194
    3.1's and boost
    Wow, I didn't realize the CR was that close between the 2. I've always thought it was a bit more different than that.
    Chris D.-
  8. #8
    3.1's and boost
    the only think I would say about boosting an older engine is besure to re-do all your gaskets and be sure to compression test each cylinder to make sure you arent getting excessive blowby. Other than that the engine should be good for boost.
    <br />1995 Monte Carlo LS Silver Metalliac
    <br />
    <br />
    Quote Originally Posted by GutlessSupreme
    <br />W-Body.com - Suspension aftermarket? Pff. Give it a few years, it'll lower itself.
  9. #9
    TurboSedan
    3.1's and boost
    i did that and replaced the oil pump and timing chain.
  10. #10
    3.1's and boost
    Quote Originally Posted by slick94prix
    Thats why when I changed my heads to the 3100 heads I wasn't worried about the .1:1 compression increase. There were some members on other forums that didn't think it was a good idea to swap heads due to the compression increase, but its so close that it doesn't matter. I was actually considering running iron head head gaskets to raise it another .4 or so, but that was when I was planning on keeping the T25 and was looking for every advantage I could get.
    Shawn
  11. #11
    Join Date
    Apr 2003
    Location
    Cincinnati, OH
    Posts
    17,684
    Thanks
    1,194
    3.1's and boost
    I would have used the iron head gaskets. Like you said, any advantage you can get is better than none!
    Chris D.-
most boost for grand prix 3.1
boost stock 3.1
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
