Hey how you guys doing?
Can any one tell me the part number for the Idler pulley on a 97 gtp? The one between the crank and the AC pulleys?
Thanks in advanced.
Thanks in advanced.
You should be able to find the part # if you search for "pulley" or something similar here.
http://www.clubgp.com/cgi-asp/partslist.asp
Also, you might want to poke around clubgp a bit, I seem to remember someone posting part numbers for aftermarket pullies(that can be purchased at local parts chains) that are far superior to the stock ones used in the earlier year GTP's.
matt f. - '93 SE, '90 Black/tan TGP(#101 of 2,749), & '90 Red/tan TGP
http://s2.photobucket.com/home/mfewtrail
TGP 1/4 mile times
1990 TGP coupe VIN database
Pulleys
If you have over 40K on the car, you should seriously consider new tensioner and idler pulleys. The stock plastic ones are crap. The bearings get hot, grease dries up and they seize. Once they seize they tend to fragment and take your belt with it. I would suggest dayco metal replacements. They are a little wider and a lot better build. Not a hard install. If you can do spark plugs you can do these.
Dayco Part numbers are as follows;
Idler Pulley (Smooth 3.5") - #89006
Idler Pulley (Grooved 3.0") - #89009
Tensioner Pulley (3.0" (Used for the NA 3.8 also)) - #89007
Tensioner Pulley (SC Drive 3.0") - #89007
The grooved idler and the larger smooth idler go on the SC drive belt along with the SC Tensioner Pulley.
The accessory belt only uses one tensioner pulley.
1990 Black TGP and 1999 Silver GTP: I love being blown<br />GTP: L32 block w/ Gen 3 Blower, S1X cam, Intercooled, 3.2" pulley, Custom-Tuned PCM, TOG headers/RT DP, 42.5# injectors, Poly Motor Mounts, AutoLite 104's, and 180 TStat<br />'04 PB: 14.212@97.65MPH; '05 PB: 14.024@98.59MPH w/ 2.076 60'; 06 PB: 13.979@101.36MPH w/ 2.35ish 60'; 07 PB: 13.517@102.04MPH w/ 2.071 60' (NOT CAMMED!); Latest Dyno: 269WHP/357WTQ<br />New England Pontiac Enthusiasts Club
Thank you very much sir... I actualy did end up getting the 89006 from Dayco about an hour ago... Im also saving those other part #'s just in case 8) ...
