Results 1 to 9 of 9
  1. #1
    stereo controls on wheel need help
    so can anyone give me detailed instructions on removal of stereo controls on steering wheel i need info asap thanks
  2. #2
    Lurker DiscoStudd's Avatar
    Join Date
    Apr 2004
    Location
    St. Paul, MN
    Posts
    3,221
    Thanks
    0
    You have to remove the airbag.
    Okay, pick your jaw up off the floor . It's really not that scary, honest.
    First, remove the fuse for the airbag (it's in the fusebox on the passenger side of the dash.) To make sure you removed the correct fuse, start the car and observe the "Airbag" light. It should remain lit if you pulled the correct fuse. For added safety, disconnect the negative battery cable.
    Now take a #30 Torx bit and loosen the 2 bolts on the back of the steering wheel and lift the airbag off of the wheel. Locate the connector and remove the green pin, then pry the connector apart. Now you can safely remove the airbag.
    Locate the plug for the steering wheel controls and unplug it. Pull the wires out of their "hiding place" and then you can pry the controls out of the wheel.
    Here's a pic of the airbag removed from the wheel:
    You can see how everything is put together...
    Installation is reverse of removal.
    If you'd like a better explanation, I have a write-up on how to replace the turn signal switch that you can follow down to the part where you remove the airbag:
    http://www.likeabigdog.com/column/94upsignal.htm
    Kevin B.
    2004 Chevy Impala 3400 V6 - Color: Victory Red
    1999 Chevy Tahoe 5.7 Vortec V8 - Color: You guessed it, Victory Red!
  3. #3
    What year is your car?
    If it's 91-93 GTP then all you gotta do is jam a screwdriver in there and pull out the button assemble.
    Why do you need to remove the buttons?
    <br />[size=7pt]2003 Impala LS&nbsp; _&nbsp; Series II 3800 _ Completely stock with 5x,xxx miles[/size]<br />Leather and roof, clean as a whistle.<br />http://gmwbody.com
  4. #4
    its a 95 GTP,, and replacement (theyre chipped)
    thanks discostudd
  5. #5
    pwmin's Avatar
    Join Date
    Nov 2003
    Location
    Front Range
    Posts
    4,098
    Thanks
    59
    no need to remove the airbag. they just pry out and theres obviously and electical connector on the back of each thats easy to get off but a little difficult to get back on. at least thats how my 96 was and my sisters 98 fbird
    1998 Buick Regal GS
    1987 V10 (SM465/LT1-L31 TBI)
    Former w-bodies - 1996 GTP Special Edition, 1991 GTP 5-speed
  6. #6
    Join Date
    Apr 2004
    Location
    St. Paul, MN
    Posts
    3,221
    Thanks
    0
    I absolutely had to remove the airbag on my old 95 'Prix. There was no slack in the wiring harnesses, and they were so snug in their little "hiding place" that you couldn't pull the wires out if you tried...
    Kevin B.
  7. #7
    all done thanks
  8. #8
    pwmin's Avatar
    Join Date
    Nov 2003
    Location
    Front Range
    Posts
    4,098
    Thanks
    59
    hmm, didnt have any problems with either one ive done. there was just enough slack in the wires.
    so, did you have to remove the airbag?
    1998 Buick Regal GS
  9. #9
    no you dont have to --it was figured out after so i got the airbag too, but all you have to do is pry out the controls and theres a plug on the back of them so just unhook and plug in the nice ones so if anyone wants an airbag i have one
Nobody landed on this page from a search engine, yet!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
