Results 1 to 15 of 15
  1. #1
    Power Steering Pump Going???
    Well for the past few weeks, I'm getting a whining noise coming from the engine bay. It sounds exactly like the whining I used to get from my old chrysler when the power steering fluid was low, adding some more always fixed it. However, the fluid level in this car is normal. Do I need a fluid change, is my pump going, or is it some other problem?
    * Signature Photo Removed* MAXIMUM SIG PHOTO SIZE 600 X 150 <br />http://www.w-body.com/forum/index.php/topic,60683.0.html<br /><br />-Matt<br /><br />http://img16.exs.cx/img16/2005/7353751full2cr.jpg<br />[quote author=Psych0matt link=topic=55208.msg689875#msg689875 date=1175093691]<br />well, you&#039;re dumb like a mac user!<br />[/quote]
  2. #2
    Join Date
    Nov 2003
    Posts
    147
    Thanks
    0
    I too, have recently developed a whining sound under the hood. I was told by one mechanic that it was my AC compressor, but I wonder if it isn't the power steering pump. Also, since I have had the car just over 1 year and still have a lot to learn about its ups and downs, could it be a idler pulley? To many things turning on that engine that could make noise.
    http://www.cardomain.com/ride/466769<br />1995 Oldsmobile Cutlass Convertible&nbsp;&nbsp; /&nbsp;&nbsp; Red with White Top and White and Graphite Interior
  3. #3
    well the whine pitch changes when i turn the steering wheel, so i'm pretty sure it's the PSP, if yours does that too, i doubt it's the AC compressor
  4. #4
    Lurker DiscoStudd's Avatar
    Join Date
    Apr 2004
    Location
    St. Paul, MN
    Posts
    3,221
    Thanks
    0
    Is it really loud? If it isn't very loud then I wouldn't worry about it. My Regal's PS pump's been making a faint groaning noise for a while now, so I just sucked out the old fluid and put some new stuff in. It still makes the noise, so I figured I'd leave it that way until it gets worse. It's been over 6 months now and nothing's changed, no leaks, no foaming, and everything looks good, so I'm leaving it be...
    Kevin B.
    2004 Chevy Impala 3400 V6 - Color: Victory Red
    1999 Chevy Tahoe 5.7 Vortec V8 - Color: You guessed it, Victory Red!
  5. #5
    If you aren't sure what is making the noise then take the serpentine belt off and spin the pumps/AC compressor. Thats how I determined the clutch had a probem on my A/C compressor.
    <br />[size=7pt]2003 Impala LS&nbsp; _&nbsp; Series II 3800 _ Completely stock with 5x,xxx miles[/size]<br />Leather and roof, clean as a whistle.<br />http://gmwbody.com
  6. #6
    terryk2003's Avatar
    Join Date
    Sep 2004
    Location
    Oberlin, Ohio
    Posts
    4,132
    Thanks
    92
    Quote Originally Posted by C-BAD
    ...my AC clutch is makes a really high pitched ringing noise ...it stops when you turn the AC on and it makes noise with the AC off, thats how i figured out it was the ac...@ first, i thought it was the waterpump...
    -Terry K.
    '03 Grand Prix GTP -
    A Couple Mods - 240WHP 333WTQ
    '05 Cobalt-
    5 Speed - Daily Driver/Beater
  7. #7
    Join Date
    Sep 2004
    Posts
    1,963
    Thanks
    2
    Re: Power Steering Pump Going???
    Quote Originally Posted by buckethead
    Probably the pump, but as long as it doesn't leak, just use it till she goes. another question, does the steering seem a little tight at idle when the car is stopped. I know that my GS started to whine a bit, and one time, after turning the wheel all the way to the lock, I had no more power steering. It turns out that the pressure realese valve had stuck.
    1989 Buick Regal GS Four Seater | 3.1L&nbsp; 440T4 |&nbsp; No Longer with a Black hood * For Sale come spring? *<br />1994 Chevy Silverado Z71 | 5.7 L&nbsp; 4L60 - E | 1 of a few<br />2000 Buick Regal LS | 3800 Series II&nbsp; 4T65-E| 1 of Many
  8. #8
    Forum Moderator digitaloutsider's Avatar
    Join Date
    May 2003
    Location
    Pittsburgh, PA
    Posts
    7,332
    Thanks
    54
    Quote Originally Posted by Regal_GS_1989
    Whoa whoa whoa. Where is this pressure release valve and what exactly does it do? Could it be any reason for a power steering rack to leak uncontrollably?
    2006 Nissan Altima SE-R 3.5L 214ci VQ35DE DOHC 60º V6 | 6MT
    Raclingline HFPCs and Y-pipe, NWP VIAS delete, Goodridge SS brake lines, removed airbox snorkel, deburgered.
    1998 Jeep Grand Cherokee 5.9 Limited 5.9L 360ci Magnum Pushrod 90º V8 | 46RE
    Flowmaster 50 SUV muffler, now with less clunks.
    1990 Pontiac Turbo Grand Prix 3.1L 191ci Turbocharged 60º V6 | 4T60-HD
    Perpetually broken.
  9. #9
    Join Date
    Sep 2004
    Posts
    1,963
    Thanks
    2
    Quote Originally Posted by digitaloutsider
    You know the noise that you hear when you turn your steering wheel all the way to lock. Well that is the valve letting pressure by so that you don't overload the system. It is located on the output side of the pump, Behind the fitting that the output hose connects to on the pump. It is spring loaded and releases under high pressure. As for the leak, it won't be caused by a pressure realese valve.
  10. #10
    Join Date
    May 2003
    Location
    Pittsburgh, PA
    Posts
    7,332
    Thanks
    54
    Gotcha. Never knew that. Thanks!
    Perpetually broken.
  11. #11
    Yup, My car's steering is awefully stiff at idle when not moving. I'll have to check into that valve in the morning. Does anyone know if that's a tough fix?
  12. #12
    Join Date
    Sep 2004
    Posts
    1,963
    Thanks
    2
    No, it's not that hard to fix. Just take the pump off the car, and undo the hoses. Next, unscrew the coupler that the pressure hose connects to on the pump. With that out, you will see what looks like a little cylinder. Play around with that until is frees up and comes out. It is spring loaded, so make sure that it doesn't go flying. Then you just put it back together the opposite of the way you took it off. I will post up a pic of this a little later this afternoon when i can get to my camera.
  13. #13
    Join Date
    Sep 2004
    Posts
    1,963
    Thanks
    2
    Well, heres the pic If you need any more descriptions, PM me, and i will send them to you.
  14. #14
    Well I've been far too lazy to actually check into that pressure release valve... but the problem has gotten much much worse. The groaning noise is much louder and is going on even when driving down the road in a straight line. So i'm finally going to tackle the problem this weekend. Just a question though, another symptom has come up. when i checked the fluid again yesterday, it was all foamy on top. Is this still indicative of a valve problem, or could there be another cause?
  15. #15
    Join Date
    Sep 2004
    Posts
    1,963
    Thanks
    2
    Yea, there was a lot of foam in py P/S fluid when my valve got stuck.
1994 chevy silverado power steering pump
2000 buick regal power steering fluid
3800 series 2 engine power steering
2000 buick regal power steering pump
power steering hose buick 3.8 1999
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
