Results 1 to 5 of 5
  1. #1
    Join Date
    Sep 2002
    Location
    steubenville, oh
    Posts
    2,400
    Thanks
    0
    vacuum hose routing
    can anyone show me apic or something of how the vacuum hoses are routed? the ones that are right by the battery is what i need. also is the brake boster different from 90 to 93? the hose that hooks to my brake booster doesn't quite seem to reach.
    Dan
    1990 Turbo Grand Prix - 5 speed, yellow tops - ~100,000 miles
    1982 Oldsmobile Cutlass Supreme - posi - 103,000 miles
    1997 Grand Prix GTP - stock - 110,000 miles
    1996 Suzuki GSX-R1100WT - 1300 big bore - ~30,000 miles
  2. #2
    Join Date
    Aug 2004
    Posts
    477
    Thanks
    0
    vacuum hose routing
    What car?
    I can help you with the Cutlass Supreme, 1992. Let me know and i will draw you some diagrams from info i gleaned when i was up to the task of fixing my autothrottle.
    1992 Cutlass Supreme S 4-Door 3.1L V6, 194k km, Raybestos Quietstops/ACDelco Platinum plugs/DIS
  3. #3
    Join Date
    Sep 2002
    Location
    steubenville, oh
    Posts
    2,400
    Thanks
    0
    vacuum hose routing
    90 gp 3.1. should be the same, unless you have a3.4...
    Dan
  4. #4
    Join Date
    Aug 2004
    Posts
    477
    Thanks
    0
    vacuum hose routing
    Okay, well, from the engine, there is a line coming off the throttle body, which gets routed towards the battery. This fits into a little doohickey that is cylindrical in shape and has a T splitter on the end.
    From the T splitter, one part goes a short distance to the autothrottle vacuum actuator, while the other is routed around the battery and down into a spherical vacuum reservoir that is located just aft of the front bumper. You will probably have to unscrew an access panel to reach the vacuum reservoir.
    The little doohickey near the battery, with the T splitter has a tendency to crack and leak, but they are available abundantly in the junkyard, so no need to fear -- just pocket one at your next visit.
  5. #5
    Join Date
    Sep 2002
    Location
    steubenville, oh
    Posts
    2,400
    Thanks
    0
    vacuum hose routing
    ok thnkas. i'll give it a look in the morning
    Dan
emission hose routing de v6 3.1
pontiac grand prix vacuum hose
96 grand prix vacuum diagram
2004 grand prix vacuum lines
2004 gtp vacuum schematic
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
